Husky 394/395 thread
2:33 AM
Cool. You guys stackem up...
srcarr52
2:33 AM
Iowa City
I like to gut it and make a big single outlet.
girlsaxe
1:33 AM
mo
Hi guys, first post.
I have a broken bottom bolt on my bucking spike, on my 394.
Can someone tell me how deep the bolt hole is? My bolt is broken off about an 1/8" in the bolt hole, and I do not want to drill too deep.
2:33 AM
Welcome to the forum.
Did you try an easy out yet?
girlsaxe
1:33 AM
mo
Hello RI, I have not done anything yet. I was going to get a left hand drill bit and try that first.
I just wanted to get an idea how long the bolt was, so I do not drill too deep.
2:33 AM
Your safe to about 3/8 to 1/2".
girlsaxe
1:33 AM
mo
I just removed a bolt from a 371, it is 5mm by 16mm long.
Dose the 394 use the same cap bolt.
girlsaxe
1:33 AM
mo
Thank you guys for the feed back. I just read today about the 3995/394 build off.
I have never built a saw before but would like to try.
Is there any generic recipe I could use to get started.
My son has a lathe, that i can use.
Fruecrue
certified hand catcher
2:33 AM
Alden NY
Get compression up. 180-200.
Get timing in the 97-100 range on exhaust, 115-120 range on transfers and 78-85 range on intake and you’ll be in the mix.
Find a way to move more air and match it with more fuel and you won’t be disappointed.
Show up with your saw whether it runs or not and you’ll have a blast.
2:33 AM
Snowmobile carb ftw
