MS 460 kits ... Finally!
thesawincanada
For the love of saws
11:16 AM
Ontario, Canada
Did you order an intake clamp also wrong one sent in kit too small. As was noted by a previous member
Nutball
10:16 AM
Mt. Juliet, TN
The thing I don't like about Hyway cylinders is how the mould halves often don't line up coupled with how the cooling fins are thick makes it such that almost no air can get past the seam in the middle. I have a couple cheaper 460 cylinders that have excellent fin spacing, thin fins, good half alignment. I noticed the same thing when comparing a 395 Hyway cylinder vs OEM, a night and day difference in cooling.
67L36Driver
10:16 AM
Sticking choke butterfly problem solved.
[emoji322][emoji322]
Stihl part on the left, Farmertec POS on the right.
See the lever that contacts the choke bell crank?
Stihl part has nice curve to it. Farmertec part is just straight.
Found the Stihl control shaft in some misc I had salvaged from a broken tank from a MS440.
Save them tiny bits. [emoji6]
thesawincanada
11:16 AM
Ontario, Canada
Operator presence leaver stick. So took handle apart massage parts. Working good. Had to clean some flashing in cylinder so I ported cylinder while there. Screw in intake to hold air filter cover came stripped so had to retap and epoxy. Complete now
thesawincanada
11:16 AM
Ontario, Canada
It went together really well. No fitmant problems. Only problems I had I mentioned above. I may get a different carb for it. Haven’t run it yet. Will put it to some wood this weekend.
thesawincanada
11:16 AM
Ontario, Canada
Sorry guys had my kids all last week had toe other saw projects on the go for other people, so I got them done first. Finally last night got around to starting up 460. And.——— it won’t light up so got to do some diagnostic to Se what I’m missing. It has a lot of compression pops off decomp every short pull. Dam wore out my arm. I’ll keep you guys posted on what I find. I didn’t like the carb right off the start and had ordered another
