Nothing happend the chain didn't fail in use but it was damaged from hitting something was Stihl 404 chain.The chain runs across the bar at about 60 mph, depending somewhat on the engine's RPM at WOT and the sprocket size. I've never clocked it with a strobe, but that seems about right. Hope you are OK, Rogue.
Um nope I don't think so ...... how many hard nose bars have you run . And I think this bloke has a handle on when a chain is done that and look at the wear indicators ......Ditch that chin. See the bottom on the links? Worn out man!
Oiler on max plenty of oil.I almost wonder if the saw wasn’t oiler wasn’t oiling sufficiently, or turned up enough to cause the chain to wear that fast. I’ve never worn out a chain itself before the cutters were worn out.
