- 10:38 PM
- Dec 24, 2015
- Coastal Oregon
Thank you for the pics Jacob. How soon do you think you will start on your dads saw?
How much bigger are the other carbs? They look like 19mm ventureThat's what it is running now and it's doing pretty good so far, but I think I can get more out of it and keep it under the lid...
A couple more notes - I was able to get new O-rings (1 7/8" x 1/8") for the fuel cap from the hardware store. For a duckbill valve,
I used a valve from a Stihl brush cutter that goes inside the tank vent. I'll find the Stihl part number for it. The rim of the opening to
the tank is pretty rough from moisture damage, so I'll lightly block sand that later to make it even.
Dose that cp block have the 101 bumps for the boost port area?
That’s cool! And even has the 125 bolt on counterweight crank
That’s cool history! I have 2 original 101b blocks that were original saw converted, both stock bore and covered in pitch chips and oil! They smelled amazing! LolI have a 394, a 346, and a Dolmar 120si to build for members here and then I'll launch into my old man's three saws. I'll do that CP conversion saw first, so we can see how
that all goes together.
My dad said it was really smooth - it was his favorite saw of the all. I chipped off about five pounds of old-growth Douglas fir sawdust and pitch from the engine. He
ran a 60" bar on it.
I think so, probably not much of a gain over the SDC-20. I have some of the fixed high jet carbs here to try also.
I am working on a 1” bore, 24mm conversion that will take some grinding but will fit, also trying to get the v4 reeds in, my buddy has been busy and doesn’t have the manifold welded yet.
That'd be great JJ. I just got back from the midwest, stopped and saw Mark and he answered a few of my questions. Let me know what works for you. I've got a few handles that are not perfect but ok, want me to bring a couple along?We can meet up in Roseburg soon if you like, Jay.
Well, the saw is complete and a runner, but needs a few things touched up: The current clutch is pretty well worn out, but I've got a new replacement (somewhere), and the
air filter needs replaced but is functional. I need to swap the handle out for a better one later (this one has been clobbered and has a saw cut in the top, but is working).
My small SDC20 101b is a ton stronger than my sp125c. I believe the small carb robs torque in bar lengths over 36", however 36" and under, the 101b IS much stronger.The only comment I'll make is I've seen vid clips of supposed 101's in 125 dress .They didn't run any better than a stock 125 .Which leads me to believe they ran a saw carb on it which is not nearly large enough to get the full potential of that engine . It takes fuel to make power .
I agree, my 101 wants to rev but it feels like a shot bar saw, it feels like it wants to make power power higher but is choked up, and in smaller wood the extra rpm cuts better, but it doesn’t have the torque to pull a long bar, it wants to drop out of the power curve. Where as the 125 chugs down better. The sdc20 is basically a 70cc carb, I wonder how much the 125 would gain with a bigger carb alone, and how much better reeds would gain on an otherwise stock 125, I remember reading mcbob had put a sloper and bigger carb on a stock 125c and it was a runner! I really want to do some testing in the future with the wb setup on a stock 125 and 101s, super curious to the results!My small SDC20 101b is a ton stronger than my sp125c. I believe the small carb robs torque in bar lengths over 36", however 36" and under, the 101b IS much stronger.
I'm curious as well as I have a new WB that was bought for just that purpose. I can tell you a BDC under the hood is somewhat problematic. I need to get the needle lever spring set correctly again. But doing anything on that carb requires taking half the saw apart.I agree, my 101 wants to rev but it feels like a shot bar saw, it feels like it wants to make power power higher but is choked up, and in smaller wood the extra rpm cuts better, but it doesn’t have the torque to pull a long bar, it wants to drop out of the power curve. Where as the 125 chugs down better. The sdc20 is basically a 70cc carb, I wonder how much the 125 would gain with a bigger carb alone, and how much better reeds would gain on an otherwise stock 125, I remember reading mcbob had put a sloper and bigger carb on a stock 125c and it was a runner! I really want to do some testing in the future with the wb setup on a stock 125 and 101s, super curious to the results!
Have heard the bdc is a pain, the wb should be easier to tune if nothing else! Is the bdc flange below the air box?I'm curious as well as I have a new WB that was bought for just that purpose. I can tell you a BDC under the hood is somewhat problematic. I need to get the needle lever spring set correctly again. But doing anything on that carb requires taking half the saw apart.
