Nutball
- 5:30 PM
- Oct 31, 2018
- Mt. Juliet, TN
An advantage the AM companies have when making pop up pistons is that they can start with a taller piston.
Has anyone noticed any AM pistons that are taller than stock? I'm guessing the Cross 390 piston is, but what about the others?
I got to thinking about this when I saw a pop up 56mm 660 BB set. I know the 56mm already free ports bad(at least the brand I got), and having no 56mm gasket, it has no squish without the gasket. So, did they machine more of a free port into it, or just make the piston taller? Hopefully we can make a more educated guess depending on how the other pop up kits are if nobody has tried the 56mm popup.
