backhoelover
SERVICE MANUAL MASTER
- 7:37 AM
- Feb 10, 2016
- lincolnton nc
k fella here is some pics of the pet9000 in uses!!!! you can get them from ddave
first we hook up leads 1 red clip hooks the small kill lead coming from coil. 2 black leads one is a ground other is for tach.
next we set the parameters. there found on service data sheet, service manual and most can be found in the op manual that come with pet9000
than you check you timing and primary volts. pri volts should not be less than 150v or +/-35%.
timing is listed on service data sheets,sm and pet9000 om.
on blowers to be able to check timing at 8000 rpm you will need to put your hand over the tube to increase rpms.
was only able to get a pic at 3000 rpm. tried to figure out how to hold throttle and tube and take a pic but wasnt that smart lol!
