MG porting
Sounds good you guys are making me want to go cut some trees down!!I like me some 064s
Lol. Now you're just teasing.See if i can help you out more. Sold this one last year
Are the KS better than mahle? I wish I took pics of the ports so we could compare them.Cool I wish I had that cylinder b
Wish I had one of those instead of two of the same cylinders like this lol but at least I have a spare if I need it.View attachment 185228
Some say they are but I think with port work to both I don't think it would make much difference I just wanted one of each just so I could back up what I just said. Lol.Are the KS better than mahle? I wish I took pics of the ports so we could compare them.
From what I understand Mason the KS had a little bit better numbers. They both are good cylinders though.Are the KS better than mahle? I wish I took pics of the ports so we could compare them.
Same same but they are out there just sneaking around.lolI’ve never held a Mahle 064 jug in my hands. Every single one has been KS that I have seen.
Yes....Does this mean my saw is a unicorn? Should I advance it past the whole key and grind through the transfers? Could be a top 3 strongest saw.
I'll sell mine to you for $300. the cylinder.lolI’ll sell you the cylinder for 300 bucks.
It's definitely the flywheel on this family of saws. I used to like the sound you knew you had a good chain/tune when they whistle/whine.Yes them too and 660’s. I’m convinced it has to be the flywheel. What else could it be?
I’ll be sold if you send me a video of it cutting one cookie cut with .050 off the rakers.I'll rebuild it from damaged parts and belt sand the cylinder for $1500...
