- 6:26 PM
- Dec 4, 2015
- In a meeting
I don’t know if the muff mod is wide enough I can’t even see the piston lol
Few Stihl fasteners in there Kevvy. Must be for more power huh?Needed more help than normal View attachment 185146
Have the kill switch & standoffs on order, can make the standoffs if necessary View attachment 185147 View attachment 185148 View attachment 185149
I preferr these Echo tank vents ....... still OEM View attachment 185150
Old habits die hard, probably no difference at all,How much of a gain do you notice from a indexed plug? I did it to 2 or 3 saws, never timed cuts. Couldn’t notice anything different though by feel but that’s not the most accurate thing to go by.
Great thing about this style of muffler mod, is that it’s tune-able, just need a regular screwdriverI don’t know if the muff mod is wide enough I can’t even see the piston lol
Adjust it as you see fit bud !I like subtle.
I ordered 4, put two on this saw, two on mine, never seen them wear outHas anyone seen the little washers between the fly wheel and the pawls wear out and cause it to slip. I robbed some off a 288 I haven’t put back together but I need to find some.
They do have a unique sound, even if they’re not too loudThe sound won’t be very subtle. They have a mean sound.
And so Jeff won’t keep asking Joe if he’s lost any muffler boltsFew Stihl fasteners in there Kevvy. Must be for more power huh?
Did you get the washers from a dealer or onlineOld habits die hard, probably no difference at all,
Indexing spark plugs can be time consuming View attachment 185157
Coming off the saw vice for the first timeView attachment 185158 View attachment 185159 View attachment 185160 View attachment 185161
She runs !!
Having some carb & recoil issues, ordered a new starter spring and am going to have to Kevorize the carb ....... she needs more fuel, who’d have thought that ??
Jacks Small Engines on line bud !Did you get the washers from a dealer or online
High speed was out 2.25 with the lever above the housing and the 62 jet. She’s around 1.5 turns out now with the 68 jet, right where she belongs. Popoff was around 35 ........ down to 21 now.Just raise the metering lever a bit. I’ve never not had one of these carbs supply enough fuel.
I was pushing hard too ........ very hard !SOOOOOOO MUCH LIKE!!!!!!!!!!!!!!!
Gotta thin out those legs if you wanna compete with the big boy porters here Kev.
