All Things 288XP
hoskvarna
12:27 PM
Iowa
Out cleaning up some cookies and noodling some biguns
Hooray 288
Sent from Hoskey Hills
quattro90
1:27 PM
Central Indiana
looking forward to joining the "288 mafia 4 life" this should be a fun week!View attachment 182331
The GOOD: Extremely low hour that seems to have spent the last 2 decades of its life on a shelf in a barn, high top w/ K&N, pressure and vacuum 100%, 2x rubber front AV and 4x spring AV in rear all in good condition. No chain rash, plastics intact, almost no wear on clutch, and the sprocket looks like it was barely used.
The BAD: Low 150psi, random bolt shoved in muffler flange that needs to be retapped and proper 'sert placed in there, wire insulation deteriorated to the point it is just falling off need to replace red/blue wires, PO used waste motor oil so the tank needs to be cleaned and the whole saw smells like burnt clutch friction material, missing muffler gasket, and scored piston. Cylinder is AOK and will be ported for extra giggles.
288M4L
upload_2019-5-20_16-17-50.pngupload_2019-5-20_16-18-6.pngupload_2019-5-20_16-18-24.pngupload_2019-5-20_16-18-38.png
beaglebriar
The Peanut Gallery
1:27 PM
Warren Center, PA
288M4L
View attachment 182370View attachment 182371View attachment 182372View attachment 182373
That saws in excellent shape!
kfd518
12:27 PM
Central Texas
That shows it nearly perfect @00wyk .
The 390/385 wrap reminds me of the 372 wrap where it looks like they put two bends in a second piece of tube and welded it to the half wrap handle.
394/5 wrap has a 4 bend straight hoop with the rear mount just welded about 2/3 of the way across the top of the hoop.
XP_Slinger
They’re Just Saws
1:27 PM
Central NY
