- 12:23 AM
- Jun 5, 2016
- Northwoods of Wisconsin
Hmmm Stump Shot, I didn't know 15 min or less was much of wrestle. Takes me longer to do the paperwork and talk with the customer. I do about 95% with the tag wire trick. Of course there are those problem versions of fuel line mounts where you got get a grommet in place or those with a two piece line setup where you attach the line to a fitting inside the tank but I don't see many of those here. I use those hook tools only to get the fuel filter out so I can check it.
The method I use only requires a precut fuel line with a little extra for the taper. Pulling the line through is easier than pushing as the line stretches so it become smaller in diameter temporarily less you over stretch it.
That tool on the top of the picture there can change out a fuel line in a matter of seconds.
