- 12:08 AM
- Dec 28, 2015
- TN
I take .060" out when I do a Solo hybrid. But, I take the exhaust up to 96.....so compression ain't crazy high. Transfers ain't as far off as you would think either. Intake comes in just right because you don't take anything off the base, and the longer stroke makes BDC further down the bore.
But.....I'm not sure if the deck height is the same between the Dolmar, and the Solo. I'm also not sure about the 7900 jug VS the 7910 jug as far as raising the exhaust that much. The 7910 jug has all that "extra" material due to the insert from the muffler into the port.
I’ve took them to 92 on exhaust. I like spacing them up and grind less with just .020-025” out.
