dustinwilt68
Wilt Built Work Saws
- 1:58 PM
- Mar 8, 2016
- Southwest PA
Nice swedish double decker bus. You should port it mang...395 I just finished up, case half had jb weld on it before, couldn't even mount the dawg, piston was scores, put new meteor piston in, used case half, new gaskets, seals, etc. This one was a G model but someone took all the G parts except the flywheel, test tomorrow then for sale.View attachment 150323 View attachment 150324 View attachment 150325
Thanks bud, I never thought about that.there is some differences between "E and II types" of these "135, 435, 440" saws. if the coil goes bad, be sure what type saw u have, or order by partnumber what's on the coil. i had once case where i tryed to swap brand new coils, between them and they only worked when they had "right" coil setup.
What is different in the xp and xpg
I do believe G is for generator and it has the circuitry and wiri g for heated handles. I have seen a couple saws modified by emergency workers and linemen that took the heated handle models, disconnected the heated handle and installed small LED work light to the front of the saw. Brilliant in my opinion. If I had to work in a bucket at night I would KILL to have a bright light illuminating the bar and cutting area.
Its not difficult. Disconnect the wires going to the handle, attach wires for an LED. Light comes on with the heated handle switch. You can fab up some sort of mount for a cat eye LED bolt. A simple 90* bracket on top of the plastic over the muffler or on the starter side.I'd like to see details on how to do that. My brother has a heated handle MS 460.
Got this one from work. Complete. Getting stripped down and cleaned and a good look over.
Thanks bud. I believe everything will be ok. But I'll know more once I get to start reassembling after clean up.I don't have a ton of stuff, but I do have a few random pieces and parts for one of these laying around. If you need something, give me a shout and I will see if I have it. Pretty sure I have a good intake and maybe an AV mount or 2.
If you need the small front AV mounts, get oem, I have yet to find an aftermarket that fits, they are all too large in diameter.
Yeah, but all he needed to do was straighten the linkage a little, lolJust snagged a straight gassed 036 from the local dealer. Clutch drum in missing, otherwise complete.
View attachment 150389 View attachment 150390 View attachment 150391 View attachment 150392
Can anyone tell me what type of shenanigans are happening here with the piece of fuel line on the control lever? Were these prone to choke linkage issues?
