MS462
sawfun
12:48 PM
Portland Oregon
The only gun I have a bipod on is my varmint rig, a Ruger M 77 in 220 Swift with a 26" bull barrel.
What cal guns, and do you re load?
I gots me one of them too. Mine has the laminated stock and a Boush & Lomb 6 × 24. She sure do like lots of 4064 behind a 50 grain tnt.
3:48 PM
I think mine is from the 1st year they came out, has a Walnut stock that I glass bedded. Also has a NLA 10X Leopold on it. I remember being in shock that the scope cost as much as the gun!
4064 is my powder of choice, but usually with 52 or 53 gr HP bullets. The Norma Factory loads were also very hot and extremely accurate, with a 48 gr bullet. However, I found out they were too hard for varmint hunting, they would just pencil hole through a chuck and he would make it back to his hole.
The HP bullets anchored them well.
I'm upset they discontinued the Winchester 120 primers, all my loads were built around that excellent primer.
When the gun was new, it would put holes in holes at 100 yds, shot after shot. It will still shoot under 1/2", but it is not the same.
sawfun
12:48 PM
Portland Oregon
I too have one of the 10× Leopold scope, but it's on an M1A. And hot and heavy battles with 220 Swifts are hard on barrel throats. I was lucky enough to have 2 Swifts thereby allowing me alternate rifles during such battles.
deye223
AIR FUEL SPARK VROOOOOM
5:48 AM
the sendero is 7mm rem mag and the ceracoated one is a 260rem
and good luck hitting a rabbit at 1000 if you don't hand load so yep
I do in the 7 I run 162g amax and in the 6.5 I run BERGER 130VLDH.
the 7 runs a nightforce nxs 5.5-22x56 with MOAR and the 6.5 has got
a nightforce nxs 5.5-22x56 with MOART .
Hedgerow
2:48 PM
I got a savage in 7mm mag..
I’ve never liked the 7mm mag..
But it shoots ok. 140 grain pills.
