- 1:41 PM
- Oct 21, 2016
- Kansas
I'm here...
So what Echo top handle takes a beating the best?
I'm here...
In the entry level categories Echo is better than Husky. We won't stock the 240 either. The 2520 blower is better than the 125B, the GT/SRM225 series trimmers are better than the 100 series huskys. The 490 and 590 saws are our best selling echo saws by far. The 310/370/400 are solid saws but tough sells here in Canada as the 490 is currently cheaper than the 370/400.Narrowing it down to the best 2 is helpful, thanks. Have to keep in mind that anytime you sell something new, you have to make an investment in parts to support it. Especially for saws in professional use. And we have that reputation of having tons of parts in stock. That's much of the rationale behind cherry picking from a dealer's perspective. Gotta support what you sell. And really why I wouldn't consider stocking the 590, even though it's a great saw. It's not just how good it is, but how good is it gonna sell. In my experience it won't sell very good in a Husky store, and we hardly need another firewood saw option. More intriguing to me are some of the small rear handle saws, cause I won't go near saws like the Husky 240. I hate them so much that I DELETED free 240's on the Fall program order. Couldn't give 'em away to me. LOL
I could see doing a couple trimmer models, have a look at the blowers. But the approach would be to ease into it, not go hog wild at the start. As far as the parts go, that's all on the distributor, and ours is one of the best I've ever seen. They do a stellar job. We are a very good Exmark dealer for them, and they don't have another Echo dealer in the entire county, so I think they'd let me do whatever I wanted to.
My CS-3000 was purchased as an ex-tree service basket case and still looks that way. In fact, the spark plug boot is still held together with electrical tape. Had a ton of dust inside the air box but p/c looked good. Did a basic rebuild on it and she runs great!
They are all pretty good, the 303T is tough as nails with a proven track record but slow. The 2511T is the hottest ticket in a small saw currently on the market and is easy to work on, comes apart in minutes.
I have a minty 341 I got from @Jon1212 on the low low after it suffered a crack in the oil tank from being dropped before it was even fired.
JB Weld ftw.
Interesting you should say that and I just got a call from a customer using a Stihl pole saw. One of his workers pulled it apart and he cannot get it back together. As I recall, Stihl designed this thing so that it almost always takes two men to connect it back up. One guy cannot do it by himself.Should also consider echoes pole saws.
Yep. Place the power unit on the floor against a wall, and rotate the drive, to line everything up.It’s not bad getting the shaft back in. @Jon1212 told me the trick. I’m not a pro but mine has been solid.
3 min job one guy.
Well we did it ten minutes, two guys. Getting the male and female splines to line up dead center is the trick. Gravity is your enemy most of the time. Prior to his arrival, the owner had already struggled for an hour trying to do it by himself.It’s not bad getting the shaft back in. @Jon1212 told me the trick. I’m not a pro but mine has been solid. 3 min job one guy.
I also have a rare beast: the CS-330T. It is also very well made and has good power. A few purists might think it's a bit heavy, but I have no problems with it. I believe it was discontinued or closed out a few years back and I could not pass up that price -- brand new for $240 delivered.
