2kworth
OPE Member
So I built my clone about 15 tanks ago. It started giving me some issues starting hot after tank fills while milling. Checked all the normal problem areas after it got bad enough that it wouldn’t idle. Found that it’s blowing an excessive amount of fuel out the carb at WOT. I suspect that I should have beveled the intake port a little before putting the saw together by look of my piston. Wanted some opinions to make sure I correct the issue. Cylinder looks good other than the bottom of the intake port’s a little sharp.
I could clean up the intake port and add a new piston.
Attempt to do a woods port, and add a new piston.
Or buy a new P&C.
Or buy a new P&C.
