View attachment 125591View attachment 125592 Working on older poulan 2300. I’m seeing light where the reed isn’t sealin all the way. Is this normal? Will it seal more when engine is running?
Take the reed off and clean the block. Over time some crap can build up between the reed and the block. It's hard to see with the reed in place.
I've flipped 2300 reeds as well.
The fuel wetting the reed will fill the .010 gap and let it seal. If the petals are not warped and the gap is enough to affect performance then you can very carefully resurface the entire contact area including beyond the screw holes. I should warn you...it's a challenging task.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
