wcorey
- 5:52 AM
- Dec 11, 2015
- ma usa
The outer ring is 100% magnetic. There aren’t an actual magnets, it appears to be impregnated with any “magnetic material” in specific locations. I did chip off a piece and applied it to each of the steel insert locations and one of them is definitely opposite polarity.
A lot of rotors are designed this way, I believe the 'magnetic material' is/can be magnetized/polarized 'after the fact' of manufacture.
The steel plates transmit the field through and give it more definite boundaries for timing and such. Probably easier than forming the actual magnets with the steps.
Before you dissected it, I was going to suggest adding new plates, that would be relatively easy to fabricate, to the location/s that were missing...
I did a lot of work modding various motorcycle alternators/rotors and often ran into the continuous band of magnetic material. These were a bit easier to deal with though as it was charging system only with no ignition timing involved.
