hseII
AKA - Karenberly's Husband
- 11:44 AM
- Dec 29, 2015
- West Georgia
be kinda difficult when mowers are loaded on it
it is going to have a small winch on it so its possible to use that for the gate but that just seems like a hassle to do every time you load or unload a mower. the winch serving double duty was one of my first thoughts on this thing but it got ruled out pretty quickly. also thought about an air cylinder since i will have a compressor and tank for the air ride but again i ruled that out as i think the cylinder diameter would have to be awfully big with only 100psi to work with
You’ve got quite a few things working against you: the weight & mass of the ramps in relation to the angles you need to load mowers being the main issue.
Our goosenecks have a 1” steel rod that goes from 1 end to the other with 1/2” plate ears that attach to the trailer frame.
The ramps are attached by pipe that just fits the Steel rod.
As I’m not at home, I had to find something on the Intertube to explain.
Now, consider a Spring Steel spring on each ramp that gives them the assist needed.
These are Attached by 1 leg of the spring going thru a 4”ish length of 1/2” pipe welded to the ramp, & the other leg hits the apron of the trailer.
