PogoInTheWoods
- 2:14 PM
- Apr 23, 2016
- Ohio
The coils I'm referring to are for the 661 only and obviously wouldn't fit other saws. That said, I understand a new v.3 MS362 is being introduced in Europe according to info in the thread above which will have a new coil with gen 3 software. Only a matter of time before it will probably be an available replacement here as will probably also be the case for the other M-tronic saws.
Also in the above thread is info indicating the WJ-134 has been replaced by a WJ-140 which comes with the newer solenoid. Be interesting to see if I end up getting one.
