- 10:58 AM
- Jan 26, 2016
- South west UK
Is it a 116 or 116SI has your piston got one or two rings
I installed a new ignition coil on my 7900 today as I have been having a hot start issue, so we shall see if it fixes it. When you guys install a new coil do you strip the end of the plug wire a small bit or is the sharp end of the spring hooked into the wire good enough? It appeared that the one that was on there (not sure if original coil or not) was not stripped on the end so I replicated that.
No
Do not strip the plug wire.
Sounds more like a fuel delivery or tuning issue to me.
I have hot start and empty tank restart issues with my Dolmar PS-7900!Cool I did it right! Yea it has been being really irritable about starting when hot and especially if I run the tank dry and after refueling it can be a real pain to get fired again, so much so that the last few times I ran it I refueled before running out. The spark plug looks pretty good to me and I am certainly no expert on carb tuning but have been trying to learn, I think I definitely erred on the side of being a tad rich perhaps I should mess with it a bit more.
Edit: Also it would occasionally (pretty rare) just die out of the blue while idling (no slow down or warning just die) and only after being ran for along time, idles fine the other 98% of the time
Out?
Let me know what You come up with!There’s no part number on it but I will ask ans see if I can purchase one
That’s the way I’ve always assembled them.Out?
More surface for the fuel mix to lubricate the bearings?
But honestly, I have no idea!
I don't think I would even use that bearing. Plastic cage? Not liking that
plus made in Portugal.
Or 2? I would be willing to pay what some may consider an exorbitant amount for some home team propaganda paraphernalia...There’s no part number on it but I will ask ans see if I can purchase one
OEM DOLMARI don't think I would even use that bearing. Plastic cage? Not liking that
