kjudd
The saw ran smooth before the cross top end. I took a huztl big bore top end off to put the cross on. Because my base gasket deleted Huztl 660 would out mill the big bore saw. So figured I would try the cross top end on it to see if the 2 would cut roughly the same.A busted spring
A cracked shoe
The oiler arm not being in the slot on the drum
Etc ......
All cause vibrations
