ms 461 woods port race thing
tree monkey
5:30 PM
wi
Prior to JB welding the uppers, didn't you compensate for the escaping charge by giving the carb more flow?
Also, I noticed the exposed steel decomp valve appears to have it's own wash pattern. Is it retaining enough heat to interfere?
I was looking for more gains, not what I would call compensating. I did it this way because of the time crunch. had I had more time I would have fixed the tr problem first.
I have no idea
XP_Slinger
They’re Just Saws
6:30 PM
Central NY
no ,I changed the tr port again, what's more important, speed or piston wash pattern?
I did get gains from the carb changes
So after all that focus on wash what did we all miss? Do you think adding the JB weld to reshape the transfer added enough restriction to choke the port causing the loss of power?
Sounds like the Saw is running great. That’s some damn good chain to go through all that testing and remain consistent.
tree monkey
5:30 PM
wi
yes I think it lost volume, went back in and took about half of what I had left in out.
before epoxt the best cut time was 8.57.
after epoxy was 9.53
after reshaping 7.99
tree monkey
5:30 PM
wi
Is the 461 a saw that has a tight case to begin with? Seems like w the long route the transfers take it would ha e a lot of volume. Not much time for transfer at 16k+ rpm tho i guess haha.
I don't worry about case volume to much, could always do a full circle crank.
