ms 461 woods port race thing
tree monkey
7:55 AM
wi
8:55 AM
Mike, reducing the oil would make the mix more volatile, which is a lower octane. Which unless it started detonating could be a good thing.
Probably what you meant.
Dan, I used to believe that, but I think you are wrong. I was on your side of the argument previously, then I researched it and learned that I was wrong.
Oil (and diesel) is lower octane than gasoline. The reason a diesel has such high compression is due to direct fuel injection timing the ignition.
The more oil is added to the fuel, the lower the octane.
8:55 AM
Diesel doesn't necessarily have high compression, but high compression is needed to combust diesel. High heat needed, or else it doesn't ignite or combust.
8:55 AM
Most diesel engines have compression of about 20:1, as opposed to about 10:1 for gasoline engines. That compression would result in pre ignition in a gasoline engine.
The reason a diesel engine does not suffer from pre ignition is not because diesel is higher octane, it is because the direct fuel injection times the combustion.
A diesel engine does not have a spark plug, but it may have a glow plug to get it running and warmed up.
