thedude74
Bonafide & Stuff !!!
- 7:21 PM
- May 23, 2017
- Alaska
Hi folks.
Been lurking around here and AS for several months now. Have found endless amounts of usefull information here. Thanks to all those who have shared their knowledge on everthing from saw specs, repair, chains, porting ect.
I have been rebuilding a Husky 285 cd for the last couple months...So far I have completely disassembled it, cleaned, sanded, painted, replaced crank bearings, crank seals, new cylinder(n.o.s.) and vec piston with oem rings, about .022" end gap(vec rings about ".210 end gap...useless), rebuilt the carb with the correct kit. Ran into some issues along the way including leaking gas from faulty vented fuel cap(cap with orange diaphram on inside), leaking gas frim where someone used too long of a bolt on the handlebar mount, I asume, and broke into the gas tank. Epoxied the hole, drilled tapped, seems ok now. Saw has good compression, havent put gauge on it yet...dont have one. The spark is nice blue...easy to see. Saw has fuel....even tried a little mix in the carb. Saw started once for about 2 seconds then died. This is after about 50 good pulls. When I assembled it used a few drops of 2stroke oil on the crank, rod bearings...used about 2 drops to coat the cylinder. Pulled the muffler...exhaust port has a film of oil on the port floor. Cleaned, removed plug, cranked a few times without plug, blew out with compressed air...thinking its flooded. Put the muffler back on tried to start...nothing....added a few drops of mix to the carb....nothing. Who needs a gym when you have one of these? Any thoughts on what I might be missing? Thanks for any and all help in advance.
