Can’t just swap carbs on mtronics. Coil, carb, harness and often the flywheelI eliminated the selenoid by convering to standard carb and checking too see if it done the same, it did. wich told me it was a coil issue because Wiring harness would nt have affected it either. After that checked coil again, this time I removed plug to reduce compression. turned it over with impact. coil with the stihl cat 40 would hit one time. and nothing else. Expaining why it would pop one time.
