Lnk
7:56 PM
East, TN
Plenty of that here too. Definitely a fan of The Macallan
I have a bottle of that unopened for when my boy gets out of the Marines. Could be as early as September. Or as late as next April. It will get opened up on his arrival. Need to get some to replace the ones I finished off for him. Lol
7:56 PM
He is actually factually correct. While you had no heartbeat, and were on your way to being dead, you technically weren't dead. Close, but not dead. They can't bring someone back from being dead, just close to dead. You were close, but no cigar!
Ok so I should start smoking cigars then
I’ll get with John to see what ones he suggests
3browns
3:56 PM
Alaska
Dolmar, doing what it’s supposed to do, cut wood
First time my son had used it
He got really wide eyed
Don't let the 6400 sticker fool you
Creamsicle, doing what it does best, getting tinkered with
Lumber was finally produced
When the gas ran out I told the son to check the oil after he fueled it
2/3 full
WTF
I asked him if the oiler was cranked all the way up
"I" dunno was the answer
Oiler was only adjusted midway
:facepalm:
Plus he still doesn't want to open the muffler up
At least I made him use my mix with Dominator at 32:1
Kids don't listen
7:56 PM
2/3 full
WTF
:facepalm:
Kids don't listen
Takes after you
Loony661
Stock chainsaws suck.
6:56 PM
Winona County, MN
Finally worked on my Chevelle a bit..
Engine mount perches bolted to frame and going over the front suspension to make sure I tightened stuff..
Probably start brake lines soon.
Brakes will just slow you down. . .
sawmikaze
7:56 PM
steeltown
Wondering if thr Burg boy showed up? You got two sipping glasses full with cigars perched? Beware of pink bunny suits!!
If I would've saw his message earlier I actually would've rode there, it's only about 45 minutes, and I can fukking cook on Ohio River Boulevard.
He would've heard me coming the final 10 minutes.
